跳转到主内容
加入维修社区 - 创建账户
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Replacement of Optical Drive
I have a 2Ghz MacBook 13" A1181. The optical drive is acting up and will not read most CDs and DVDs. I have a PowerPC model MacMini sitting on shelf. Is the MacMini's optical drive compatible with the optical drive on a MacBook of this model?
Thanks,
mark
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for the info. I am assessing my options overall. I will most certainly consider this site for purchase of a replacement drive, if I go that route.
Cheers,
完成的
添加一条评论
1个答案
已选择的解决方案
The older MacMinis used 12.7 mm optical drives and your MacBook uses a 9.5 mm drive. So no they can't be interchanged. http://www.ifixit.com/Mac-Parts/Mac-mini...
For some things, not involving the system. the MacMini could be set up as the master drive in Target mode to install to the MacBook. System things will not work because it would try to install PowerPC instructions instead of Intel.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Star Gazer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 910
