跳转到主内容
加入维修社区 - 创建账户
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
Laptop not booting, fan spin for a few seconds then stops...
Hello, whenever I try booting in the fan spins for a few seconds and then it stops. There is no input on the LCD. So I tried it with an external monitor. Still no luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
i have acer 5532 and it have exactly the problem that oldturkey03 have so idont have another laptop to test the hdd or the ram so what should i do ?? beside i remove the cmos battery and want 10 min and then return it back and still the same
完成的
添加一条评论
4个答案
已选择的解决方案
Abel Benoie this “booting in the fan spins for a few seconds and then it stops “ is normal behaviour from the fan. It does it because your computer does not boot or post. This could be related to pretty much anything from bad RAM, bad HDD to a bad processor.
这个答案有帮助吗?
得分 4
3条评论:
I have checked the HDD with another computer and I can confirm that the HDD is not the issue. I would like to purchase some new RAM but I'm not sure where to get DDR2 RAM. And anything more than 40 bucks would be too much money on a laptop this old.
完成的
Thank you! Turns out it was bad RAM, I managed to salvage a 4GB stick of RAM from another computer. It works now!
完成的
T15 Gen 2 having this exact same issue - I pulled the heat sync off and screwed it back in that seemed to be the magic fix for me.
完成的
添加一条评论
最有帮助的答案
Hi,
Try a full power refresh in case the BIOS has become corrupted and is preventing a normal start i.e the laptop is not passing POST (Power On Self Test)
Here’s the procedure:
a). Disconnect the charger if connected.
b). Remove the main battery from the laptop.
c). Disassemble the laptop and remove the coin cell RTC battery from the motherboard. Here’s the service manual for the laptop. Click on Contents > Coin cell battery to view the necessary pre-requisite steps and then the procedure to remove the battery. Note the orientation of the battery for when you have to re-insert it. It is +ve on top - marked on battery. When the battery is removed from the laptop, use a DMM (voltmeter function) to measure the battery’s voltage. If it is <2.6V DC replace it. Usually the battery is a CR2032 Lithium coin cell battery that is available most everywhere. Check the battery type, printed on the battery itself, to verify the type number in case it is different.
d). Press and hold the laptop’s Power on button for 30 seconds and then release. This will restore the BIOS back to the factory default settings.
e). Reinsert the coin cell battery (or replacement battery) - remember the orientation!
f). Reassemble the laptop, reinsert the main battery and connect the charger.
g). Switch on the laptop and check if it starts OK. There may be a message on the screen about the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected, the message won’t appear the next time that the laptop is started.
这个答案有帮助吗?
得分 5
10条评论:
I don't have a DMM :(
完成的
@Abel Benoie
Then just reinsert the battery after pressing the laptop Power on button for 30 seconds as described above. The idea is to drain all the power from the motherboard to remove any corrupted settings that may be being held by the battery even though it is low perhaps. The battery check was only in case it was low and this can allow the corruption to occur.
If the problem was a corrupted BIOS then the laptop will start OK but you may have the same problem again very soon.
If you do then you know that replacing the coin cell battery on the motherboard may stop this from happening.
Also if you're getting into repairing computers etc, then I suggest that you invest in a DMM and learn how to use it if you don't already know. Even the cheapest ones that are available from major hardware stores are useful. e.g. you can measure the voltage outputs of chargers, test battery voltages, use the DMM's Ohmmeter function to make sure that the DC-In jack in a laptop is OK etc etc. Just simple checks I know but they save a lot of time when trying to find problems
完成的
Hi all, I have the same issue, tried draining power following the above method, I also removed the ram completely and I’m not getting any beeping still or display ?
完成的
@David H
What is the model number of the PC?
What if any lights are showing on the PC when trying to start it?
完成的
Thank you so much @jayeff .
I followed the procedure and it worked .
完成的
显示更多的5条评论
添加一条评论
Hi all, I managed to isolate the issue due to the amount of light blinks if any you see when you first try and turn the laptop on. I have a Dell XPS that has the exact same problem noted above, not sure if HP machines do to the same to help with diagnostics however my machine beeped or flashed a small light where the usual HDD & PWR indicator lights are usually found, 5 times from memory, 3 long and 2 short….something like that. When I checked further into Dell trouble shooting, the beeps translated into a CPU issue, which unfortunately it did turn out to be….hope this helps
这个答案有帮助吗?
得分 0
1条评论:
@davidh49712 seems like every case is different. on 10/29/2020 the OP stated that "Thank you! Turns out it was bad RAM,"
完成的
添加一条评论
I fixed mine by reseating the ram and SSD.
这个答案有帮助吗?
得分 0
3条评论:
Hi,
I've experienced an issue with my laptop. When I try to power on, the power button light turns on, and the fan spins for a few minutes and then stops, then spins again. But nothing boots up on the screen. The screen remains black
I've already tested with a new ram and a new Hard drive. But issue still persisted.
完成的
Same here, i have a lenovo ideapad3 15IGL05. It does tht. Tho it has inbuilt ram, the hdd is fine
完成的
با سلام مشکل لب تاب من هم
. وقتی سعی می‌کنم آن را روشن کنم، چراغ دکمه پاور روشن می‌شود و فن برای چند دقیقه می‌چرخد و سپس متوقف می‌شود، سپس دوباره می‌چرخد. اما هیچ چیزی روی صفحه نمایش بالا نمی‌آید. صفحه نمایش سیاه می‌ماند.
完成的
添加一条评论
添加你的答案
Abel 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 129
过去 30 天: 627
总计 83,173
