Turns on, has sound, and backlight appears to turn on, but no picture.
My LG TV 32LB560B-UZ television will turn on, and the sound seems to work fine, but there is no picture. The backlight appears to turn on; the screen is still black but noticeably ‘brighter’ when the tv is on than off, and I can see lights inside when I look into the vents. I tried unplugging and replugging all the wires attached to the boards, but this didn’t do anything it seems. I’m not sure if any of the boards are damaged, so I attached pictures of them below. Any ideas on how to fix it?
I'm having the same problem with my LG 50uk6090pua. I've replaced the main board which failed to resolve the issue. If you find a fix please update. I'm thinking about replacing the power board next.
由 Tony Phillips 完成的
My LG 55" SMART TV, with backlight and sound but no picture, I used it only for almost one year and 3months, what is the problem?
由 EDDIE 完成的
@eddie7857 what exact model is it and what have you checked and tried to fix this?
由 oldturkey03 完成的
