跳转到主内容
加入维修社区 - 创建账户
First Manufactured: Dec 2011 Sync master 20 inches with a resolution of 1600 x 900. It also has an option like Magic angle and magic tune.
What to do if display gets damaged after cleaning with chemical?
Yesterday I was cleaning my monitor with Colin (cleaning agent). I directly sprayed it on display and wiped it with a dry cloth. After cleaning, I thought to turn on my PC and check for the display but it worked fine. Today when I turn it on my PC I saw that there were some blue lines in the middle of the display. What should I do now? Please assist me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Display mein white light bling ho rahi hai aur Baki policegiri
完成的
@samsung1930 what white light? The backlight or the power LED?
@samsung1930 kaun see safed roshanee? baikalait ya paavar eleedee?
完成的
添加一条评论
1个答案
最有帮助的答案
Vinayak Mohakud  could be something shortened out or streaking on the diffuser sheets. We will have to see what it looks like. Post some good pictures of this with your QUESTION.
在已经存在的问题里加入图片
If it is something that has shortened then we will have to dig a lot further. If it is the diffuser sheet, you will have to disassemble the panel and replace the sheet. Neither one of those things are any fun :-(
For the future you now know to never spray anything directly on a screen. Always spray it on a cloth (like microfiber clothes) and then wipe the screen gently.
这个答案有帮助吗?
得分 2
3条评论:
Actually, to show the lines clearly I have drawn a black background.
完成的
@Vinayak Mohakud looks like the LCD driver board(s) got affected. Those are part of the panel. You can try and disassemble your montory and check the driver board for any shorted components..... but ultimately this does not look good
完成的
Now a rainbow colour strip is appearing.
完成的
添加一条评论
添加你的答案
Vinayak Mohakud 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 53
总计 2,345
