跳转到主内容
加入维修社区 - 创建账户
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Mercedes-Benz cooling system temperature
My Mercedes-Benz cooling system temperature decrease when I drive for a long time, nevertheless there is a thermostat in the system. The temperature is between 50 and 80 celisiou but it should be stable at 80. Are there any reasons for that
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Coolant thermostat failure or perhaps someone has removed it. It is easy to remove and observe thermostat behavior in a pan of heated water on a cooking surface. These devices can come apart eventually due to corrosion and normal wear.
这个答案有帮助吗?
得分 4
添加一条评论
@mohammedmerc check your temperature sensor to the gauge to make sure that your temperature truly decreases with longer drives. We would need to know the exact year and model of your MB to try and help you further.
这个答案有帮助吗?
得分 3
1条评论:
My Mercedes-Benz is 1978
完成的
添加一条评论
添加你的答案
mohammed elsharkawy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 284
