跳转到主内容
Repair and service information for the Lenovo IdeaPad 305. Released in 2015, the Lenovo IdeaPad 305 line consists of 3 bright colors and Dolby Advanced Audio.
4 个问题 查看全部
Why does my Laptop stuck in running circle?
So It all started today after I finished my online classes and well My laptop just stuck and wont start. I tried turning it on and off and pressed all the button and stuff but still it won't work and this is the only thing that shows up
. Help I really want to fix this as soon as possible because of my online class. Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Maybe hard drive died.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Try the following:
Turn on the laptop and when it boots into Windows, force turn it off by holding the Power button until it completely shuts down.
Do this 3 times in a row i.e start > boot > turn off > start > boot > turn off >start > boot etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
When in the menus select Troubleshooting > Startup Settings > Advanced > Startup repair and follow the prompts.
If that doesn’t work try Troubleshooting > Startup Settings > Advanced > System Restore or System Image Recovery (if you have a restore point set or system image that is).
Do not select Reset this PC. If you choose a wrong option after this you may lose all your data as Windows will be reinstalled.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Silver Acetate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 426
