跳转到主内容
加入维修社区 - 创建账户
小米旗下 Amazfit 品牌的方形塑料智能手表,发布于 2017 年。
battery not holding charge
My device is only 07 months old ( out of warranty)……it only holds charge for about an hour or so….and when you plug it back in….it shows fully charged in about 5 minutes but after removal from the dock….holds charge for only an hour or so……All this happens on custom watch faces…..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
10条评论
I just can't find a new battery for this my Bip. The battery is dead, but I love this watch so much that I'm willing to replace the battery myself if only I could buy a new one…
完成的
=== Very fast drain my watch battery pls help and reply soliution ===
完成的
Me also facing the same problem. My watch is 20 months old.
完成的
Amazfit bip lite smart watch for battery change Kar na he battery nahi mila rahi he to kidha jana ho ga
完成的
Plz answer me help plz plz
完成的
显示更多的5条评论
添加一条评论
3个答案
已选择的解决方案
Hi @Luis Silva
Search online for PL402120V to find suppliers of the battery that suit you.
Here’s an image taken from this teardown video of the smartwatch that shows the battery specifications.
(click on image to enlarge for better viewing)
Here’s a supplier just to give you an idea of the cost of the battery. Make sure that if you use this supplier that you select the correct battery model!
这个答案有帮助吗?
得分 2
2条评论:
Hi @jayeff ! Thank you for your answer! I will try that provider as soon as I can. I'm a bit worried that those batteries may have some issues, but I will give it a try.
完成的
@Luis Silva
As I said try searching using the battery model number I posted to find other suppliers.
You can only hope that the batteries are OK as most probably they're all made in the same country anyway. Looking at the video the harder part will be opening the watch to access the battery rather than just changing it.
Good luck with the repair!
完成的
添加一条评论
Hi Sharjeel I have the same watch as you Amazfit bib A1608 with a bad battery that holds a charge for no longer than 15 minutes but when put on the charger it charges very quick but drains fast so we have the same problem I have found the correct battery at informa@impextrom.com but are out of stock at the moment 30-04-2021 so register with them or phone them for information.
Good luck Bob
这个答案有帮助吗?
得分 0
2条评论:
Thanks alot Bob...
完成的
need new battery for amazfit bip
完成的
添加一条评论
The problem is the charge controller. Mi bit starts drain battery after 3 years. In a day it drains about 20% of charge for no reason. I change the battery. It shows 100%. After two days the battery is dead and I cannot recharge it by the watch. With a voltage meter I measured the voltage on battery plug on the watch discovering the voltage by motherboard is about 0.3V an not 4.2V how it should be. Thus I think in a charge controller problem that drain the battery and not charge it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharjeel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 47
总计 6,871
