跳转到主内容
加入维修社区 - 创建账户
Released in early 2017, the Dell Inspiron 15 5578 2-in-1 is a convertible laptop with a 15-inch touchscreen. It uses an Intel processor and Intel integrated graphics.
Why isn't the ac adapter charging the battery?
The Ac adapter powers up the laptop but isn’t charging the battery so what do I look for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @longoman ,
Check that the battery is being detected in Device Manager. Here’s a link that may help
If it is and the above didn’t resolve the issue, create a Win 10 battery report and check the status of the battery.
If the battery is faulty and needs to be replaced, here’s the service manual for the laptop, taken from this webpage.
Go to p.14 to view the necessary pre-requisite steps and then the procedure to remove / replace the battery. Usually batteries have model numbers printed on them. If you search online using the model number of the battery you should get results for suppliers of the part.
这个答案有帮助吗?
得分 2
2条评论:
Battery replaced. Same problem so it has to be the charging circuit gone bad.
完成的
Hi @longoman
Can't find a free download online for the schematic but if you're willing to spend a bit you can purchase it.
Maybe it's only something minor in the charge circuit that's gone wrong. ;-)
完成的
添加一条评论
为未来的维修做好准备
全部购物
the charging circuit may be dead or the battery is aftermarket and not recognized as legit, or the needed pins may be dirty
这个答案有帮助吗?
得分 1
1条评论:
You're right about the charging circuit at fault. I advised the customer to keep the power plugged in to avoid power cut off unless he's willing to replace the logic board ($$)
完成的
添加一条评论
添加你的答案
Steve Longo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 22
总计 231
