跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Washer is Bouncing around
I've tried to balance the washer - one of the foot screws isn't really moving up or down... but it's almost nearly perfect (barely off).
Started the washer and on the spin cycle it bounces all over the place. I was told it might be the drum? Is this something I can trouble shoot or do I need a repair person? (if it's something as simple as taking a panel off and adjusting something - I can do that... if it's replacing a major part - a pro should do it)
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Jessika, you might want to check to see if you find any obvious problem with the springs or other support items. If you do not see anything obvious, I would think that your most likely problem will be the shock absorber. A diagram as well as parts are available right here. Good Luck and let us know how it is going.
这个答案有帮助吗?
得分 3
1条评论:
Thank you for your help! Found out from reading other posts that there is a filter inside the washer and when it was taken out - there were 2 socks stuck inside!!! Much appreciated!
完成的
添加一条评论
添加你的答案
Jessika 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,823
