跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
fv 274 av dc jack
I have a dv 7 fv 274 av and think it may be the problem and want to make sure not to get the wrong part . When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out, When I don’t touch it and the light goes on the battery charge but not completely. Somehow the os is now corrupted and I can not get the computer to stay on long enough to do a repair of the system. My thought was a correct replacement of the jack might lead to be able to use the machine again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
murohyg27 this sentence in your description “When plugged in if I play around I can get a light showing it is on and charging, the slightest movement and the light goes out. If I try to power it up the light goes out “ would lead me to changing the DC in jack first. This video should be pretty similar to your system. Of course, you can download the service manual from here
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
murphyg27 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 187
