跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy J1,于 2015 年 1 月发布,型号为 SM-J100VPP/SM-J100H。
How can I fix my dim screen?
I dropped my phone, and the screen went black for a while, but when it turned on again, the screen brightness was very dim, although the screen brightness setting was on high. I am not able to use my phone during the day. Please help me out, how can i fix it at home?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @thiccislander ,
The fall may have loosened the cable connection from the display assembly on the systemboard. Worst case is that it internally damaged the display assembly or something in the screen’s backlight power circuit on the systemboard. The display assembly cannot be repaired. It has to be replaced
As a DIY repair all you can do is to open the phone and check the display flex cable connection on the systemboard is secure and if so, then is to temporarily replace the display assembly to prove whether the problem is in the display assembly or in the systemboard.
Here’s the ifixit 三星盖乐世 J1 / J100触摸屏与LCD屏幕的更换 guide which may help.
Replacement screens are available online. Just search for Galaxy J1 LCD screen to get results for suppliers.
If doing all this seems to daunting for you, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Olivia Drauna 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 926
