跳转到主内容
Repair information for the first generation Isuzu Trooper. Available as short or long wheelbase three or five-door wagons with 4-wheel drive and independent front suspension.
2 个问题 查看全部
Wipers getting stuck + motor drawing power
Hi, I have a 1984 Isuzu Trooper 3dr. Lately I’ve noticed that sometimes the wipers would randomly turn on when I started up the car and simply stop in a random position. Then I can’t get the wipers back down unless I pull quite hard on both of them.
The motor is drawing power as well (car had a voltage gauge for some reason) and it’s honestly irritating. I’ve replaced the wiper motor 3 times already and since it’s the rainy season over here I really don’t to be stuck without wipers in heavy rain again.
Is there anything I can do other than replace the motor yet again?
(As if anyone here actually knows about these 1st gen Troopers…)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@ngs765 could be wiper linkage problem. If the linkage binds it will require more work from the motor and like you said a motor replacement does not permanently fix this. Check the linkage by removing the cowling just below the wipers.
这个答案有帮助吗?
得分 1
1条评论:
I had suspected that since the passenger side wiper sometimes is out of sync. I'll try to fix that.
完成的
添加一条评论
Often times the headlights must be turned on for the wiper cycle to complete. It was a safety design protocol from the late 70’s.
just a guess however.
这个答案有帮助吗?
得分 0
添加一条评论
Tu problema es que se rrcecan los ejes donde van los brazos de los cepillos .desarma todo el varillaje lubrica los eles con poca grasa cambia los bujes plásticos que acopla el motor y el segundo brazo .vuelves a montar y tu problema estará resuelto .
Google translate:
Your problem is that the axes where the arms of the brushes go are damaged. Disassemble all the rods, lubricate the rods with little grease, change the plastic bushings that connect the motor and the second arm. Reassemble and your problem will be solved.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amatsuda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 128
