跳转到主内容
Released April 2015, also known by model name A10-70F ( 'F' representing that this is a wifi only model)
47 个问题 查看全部
How can I fix my charging port?
Everything on my Lenovo tab A2 10 works except the charging port. When I plug in any charger it won’t charge the tablet. When my tablet lost its final charge I couldn’t use it anymore. I know its not the battery because it worked just fine its just charging the tablet was getting progressively harder and I had to angle my chargers in different ways so it could start charging the tablet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Where did you buy replacement charging port ? I saw some generic ones on Ebay.
完成的
添加一条评论
1个答案
最有帮助的答案
@sal10 sounds like a bad charging port. It is soldered to the motherboard. Use this guide Lenovo Tab 2 A10-70 Motherboard Replacement to get there. Then you need to remove the old port and solder a new one in. This video has some pretty good directions. The ports are available at places like this
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Salvador 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,511
