跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Samsung TV.
Samsung tv doesn't show image, but shows text 'smart tv' when turn on
UE55MU61KXZT
Hello, i got a troubled tv, after almost 2 years it didnt see any signal from antenna and hdmi ins, after remote help from samsung they sent me technicians and changed motherboard in warranty.
After 10 months the exactly same thing happened (but this time it’s out of warranty) so yesterday they tried again connecting to it remotely but couldnt fix the problem.
Now today the tv is not showing any image, it turns on, it shows the starting text ‘Samsung Smart tv’ and then turns black, after i tried an hard reset with the power button it turned on, stayed for 20/30 seconds blue then suddenly it worked as usual, could see Netflix but just for 1 minute and then it turned black again, so i have no idea what to check
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@luck5 this does sound like a main board issue or possibly a T-con board. Verify that your TV is a Samsung UN55MU6290
这个答案有帮助吗?
得分 0
2条评论:
hey, thank you very much for your answer, my tv model is actually UE55MU61KXZT
These last days it 'kind of' works, it stays black for many minutes when i turn it on and after a while i can see it, but only web services, antenna and hdmi are still dead
完成的
@luck5 this "but only web services, antenna and hdmi are still dead" really sounds like a main board issue
完成的
添加一条评论
添加你的答案
luck5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 151
