跳转到主内容
加入维修社区 - 创建账户
于2015年十月26日上市的第四代Surface Pro平板电脑。
Using the original screen
I have the dreaded hot batteries that has caused the screen to delaminate from the frame. There is quite a separation on the right hand side ``
``and a smaller on on the left hand side
of the screen. There is very little discoloration on the screen and there is no flicker.
It is out of warranty and Microsoft will swap me a “similar” refurbished Pro 5 for $599.
Question: Assuming I can detach the screen with no damage, can it be reused (or did the heat causing the delamination stretch it, too)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@tigershark125 going by your description it appears that this is “only” a delamination. IT won’t have stretched it so you can reuse it. You may even find that some sort of adhesive (OCA/LOCA) could minimize the effect of the delamination. Post some images of what you are looking at, with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
2条评论:
Added pics and thank you
完成的
uioe the delamination. Makes me wonder why. Anyhow I'd proceed with a very careful attempt of removal and the relaminated with some have duty UV adhesive.
完成的
添加一条评论
添加你的答案
Walter Peycha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 17
总计 108
