跳转到主内容
The Lenovo IdeaPad 310 Touch-15ISK was released in July of 2016. The Lenovo IdeaPad 310 Touch is specialized for multimedia endeavors.
14 个问题 查看全部
laptop display showing 1 pink and 1 green line
my screen is showing 1 pink and 1 green line in the middle but when I open a white page , lines get disappeared…..they are also showing in bios menu and in windows startup……pls help me solving the problem
I also tried updating my intel vga graphic driver but the problem didn’t solved
my laptop is lenovo ideapad 310
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Neetu Gagneja  that sounds like a display issue. Move the screen slowly back and forth and see if those lines change. Connect an external monitor and see if the lines show on that one. If all of that looks ok then you need to consider changing the screen.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
To add to the good answer here's the hardware maintenance manual for the laptop. Go to p.52 to view the necessary pre-requiste steps and then the procedure to remove the LCD unit.
完成的
添加一条评论
添加你的答案
Neetu Gagneja 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 532
