跳转到主内容
An LED smart TV released by Samsung in 2013.
18 个问题 查看全部
Has power but no display
I have power to the tv because I installed lights that connects to USB port in back but the screen no long have a picture or when you turn it on where it has the box that tells you that you have no connection any longer. I took the lights off to see if that changed anything but it didn’t. Still turns on but I still have no lcd display. Any suggestions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
rscillion0311  all that the lights installed show you is that your USB port gets power. You will have to remove the back cover from your TV and take a look at the power board as well as the main board. Measure the voltages on the power board and let us know what you get. Disconnect the wire from the power board to the main board and see if your TV’s backlight comes on. Post some good pictures of your boards with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
For now, this does sound like a power board failure.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rscillion0311 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 6
总计 243
