跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
How to fix digitizer cable on LCD replacement
Hey,
I ordered a new replacement screen for my z3c. Yet, on replacing it I realised that the digitizer cable keeps getting loose from its socket (?). Thus, while the screen itself functions, it is unresponsive to touch (of course, since the cable does not stay attached to the socket. Any ideas ? I have my old screen that is responsive to touch but has a broken lcd - can I somehow use its digitizer on my new screen?!
I hope my question got clear - I am missing a lot of technical vocabulary in English.. Sorry.
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@alb3rt if your old display assembly stays connected to the motherboard but your new one does not sit properly and comes loose again, it is the connector on the cable. In theory, you could replace the digitizer but would need to have the right machinery to separate it. Then you need the right machine to reinstall it as well as the right glue etc. All of that machinery is costly and needs practice. Your best way would be to replace the entire display again and consider the one you have as a loss. Make sure that the connector on the board does not have any bend or broken pins etc. Also, it may help is you post some pictures of the connector etc., with your QUESTION. That way we can see what you see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
albert einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 205
