跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
2013 iMac 27" SSD only upgrade
I’ve got a late 2013 iMac which was ordered with a small SSD instead of the HDD or Fusion drive. I want to install a 2TB 2.5” SSD, but not sure what to expect when I open it up. Will it have any of the following inside?
  1. Mounting brackets
  2. SATA cable
  3. Sensor cable
Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would start off getting this kit iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit Then you only need the logic board SATA cable 27” iMac SATA Hard Drive Combo Cable, Apple P/N 923-0312
Here’s the guide to putting it in iMac 因特尔 27" EMC 2639 硬盘更换 You will still need to lift the logic board forward so you can get behind it to clip the SATA & Power cable ends in. Pick up from Step 35 in this guide iMac Intel 27" EMC 2639 Logic Board Replacement and stop at Step 56. Here’s a better image of the connections
Plug in the adapter sensor cable and then into your new drive and re-assemble jumping back to Step 33 in the iMac Intel 27" EMC 2639 Hard Drive Replacement guide.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.图片
产品
$122.99
iMac Intel 27" EMC 2639 硬盘更换图片
指南
难度:
中等
30 minutes - 2 hours
iMac Intel 27" EMC 2639 Logic Board图片
指南
难度:
困难
1 hour
这个答案有帮助吗?
得分 1
7条评论:
Thanks Dan, that’s really helpful. It’s as I feared, I’ll have to do the near-complete teardown. I have all of those parts, only I'm missing the little pins to secure the drive enclosure to the right and left brackets. Might have to improvise because tomorrow's the repair day.
完成的
@MacMike47 - Make sure you use the pizza cutter and don't pry deeply as you can damage the display.
完成的
Okay, it's mostly good news:
I replaced the power supply (that was the main issue, where it kept randomly shutting down), installed the hard drive enclosure with my SSD, with the new SATA cable and an OWC thermal sensor cable. At that stage, I did a test boot, but the SSD wasn't showing up. So I swung the lid open again and tried plugging the SATA cable directly into the HD enclosure (ie without the thermal sensor cable). Sure enough, it then worked a treat!
So my question is: Given this machine was BTO with a PCIe flash drive only and no hard drive at all, does it even need a thermal sensor? Surely the computer doesn't need to know the drive's temperature because it doesn't know there's anything there... Or is that just me being hopeful? Or is it a faulty sensor cable? In any case, I've had the iMac on now for 30 mins without any excessive fan noise.
The amount of dust in there was horrific, so getting most of that out must help with cooling.
完成的
So Apples direction of sealing the computer up so tight was a good thing? Not! Unless you have a dust & debris clean room you need to clean out the system! So crack it open in a year or so to give it a clean
As far as the sensor Apple did alter the systems firmware so Mojave and newer altered things up. so the sensor is not needed. If you are running a newer macOS you should be OK. How about installing a good thermal monitoring app like TG Pro to keep an eye on things.
完成的
Great idea re TG Pro, thanks. Yes, I'm running Mojave so all good there. I inherited this machine from someone in a very dusty office, so it should be good to go in my relatively clean flat for a few more years.
Who knows, maybe the super efficient ARM iMac will be completely sealed and dust-proof.
Thanks so much for your input.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
MacMike47 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 1,240
