跳转到主内容
加入维修社区 - 创建账户
2015 年 12 月发布的混合笔记本/平板电脑。Acer Chromebook R11 由宏碁(Acer)制造,是该系列经济实惠的笔记本电脑中一款低价选择。
Can I replace the DC-in jack?
When I try to charge my R11, the power cable sits very loosely in my device, and it will only charge when held at an angle.
Can I replace the DC jack, without replacing the whole motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @joboy ,
You don’t have to replace the motherboard only to remove it from the laptop case to work on it but you would need to have smd (surface mount device) soldering skills and tools to do the repair.
Here’s a teardown video of the laptop. It is useful as it shows how to disassemble the laptop to remove the motherboard so that the DC-In jack - supplier example only can be be resoldered to the motherboard if it is just loose or replaced if necessary.
Here’s a video that shows how to replace the DC-In jack on the motherboard. I realize that the laptop in the video is not the same model but the procedure is the same.
If you find that doing this yourself is too daunting a task, contact a reputable, professional laptop repair service and ask for a quote.
这个答案有帮助吗?
得分 3
1条评论:
Thank you very much. Your answer explained it perfectly.
完成的
添加一条评论
添加你的答案
J D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 726
