跳转到主内容
Akaso EK7000 is a 4K Ultra HD action camera. The camera was released in January 2017. The camera comes with built-in WiFi and can be remote controlled.
5 个问题 查看全部
Half of Screen messed up
I have had the akaso ek7000 4k ultra hd since christmas 2019 and it is having a problem now. When i turn it on half of the screen is like blue transparent. What could be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Tyler Sawyer could be a bad screen or a bad connector. You do want to see if you can reseat the connector, making sure all the pins are clean and straight etc. If those are correct, try a new screen.
这个答案有帮助吗?
得分 0
添加一条评论
Just be aware too … the drivers for the screen are part of the firmware, so you can't use just any LCD screen (if you are replacing a broke screen)
if you update the firmware - with the wrong version, this will also cause problems - since the driver won’t match
  • more bad news …. the 4k is fake, so is the picture resolution
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler Sawyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 108
