跳转到主内容
加入维修社区 - 创建账户
Google Pixel 2 是 Google 的第二款旗舰手机,发布于 2017 年 10 月 17 日。该手机配备 5 英寸 AMOLED 显示屏,有 64 GB 或 128 GB 存储版本可选。它有三种颜色:纯粹黑 (Just Black)、清晰白 (Clearly White) 和有点蓝 (Kinda Blue)。
Why does the screen keep lifting up?
I replaced the battery and display in my Pixel 2. Put everything back together, went great. Screen works.
BUT. The screen keeps lifting up. I used brand new adhesive and made sure all the old adhesive was removed. Took it apart, re-set everything again with new adhesive, but it still keeps lifting up.
It’s almost like either the battery itself is too thick, or the cable on the back of the new display is too thick? Has anyone else had this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
I tried putting in the old display with new adhesive when I replaced the battery. The battery works well but the upper right corner of the display does not seat well and comes up less than 1/16 inch. I bought a new display and the same thing happened. The screen works except after making a call the screen goes blank! I can talk but can’t hang up because there aren’t buttons (the screen is blank). Sometimes, I can briefly recover the screen and hang up by applying pressure with my thumbs on the opening at the top of the phone for the speaker.
由完成的
添加一条评论
1个答案
What adhesive did you use and did you do anything to “cure” it?
In my shop I use the black Tesa tape whether it’s pre-cut for a specific device or I use the rolls of adhesive. I’ll heat the device up with a heat gun and then use a few small Irwin Quick Grip clamps to apply pressure and it works really well. Also when you apply the adhesive, make sure you don’t touch it. The oils from your skin can have a negative affect on the adhesive. You can also try 3m adhesive promoter. But WHATEVER you do, for the love of God, DO NOT USE SUPER GLUE.
这个答案有帮助吗?
得分 0
1条评论:
I used the pre-cut adhesive twice and the tesa tape once. I did not heat it up to cure it, though I did put a book on it overnight to try to get it to set. It was okay for a day and then after that no good.
Do you know if I should remove the black film on the backside of the replacement screen? Context here: 谷歌 Pixel 2 屏幕组件维修更换指南 (that should link you to my comment on the guide)
Thank you for your help!!
由完成的
添加一条评论
添加你的答案
Raquel Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 1,154
