跳转到主内容
加入维修社区 - 创建账户
E2310H 由 Dell 在 2009 年左右发布,是一款分辨率为 1920x1080 像素的 23 英寸显示器。
Monitor lost power suddenly
During work, my E2311H got black and I’ve no chance to power on again.
Is there any spare part to check or anything else I can do myself to get it back to work.
Greetings
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hi @lassegismo
What I can suggest if it is not under warranty, to open out and check on the power supply voltages.
normally i can think of, either power supply board faulty or mainboard faulty which causes this.
do you have a multimeter with you?
由完成的 分享
@augustine yes i check the power supply and there is 18.5 autput for both boards but the backlight plug have no power i found 2 blown 25v 220 capacitors and change it but still not working
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
If there is still no backlight voltage, check the PSU diodes with the diode function of a DVM. If all of them check OK, check the transistors the same way = they are just two diodes b to e and b to c. I'm betting on diodes.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lasse Gismo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 975
