跳转到主内容
加入维修社区 - 创建账户
苹果第五代智能手表,可选蜂窝网络版本,于 2019 年 9 月 20 日发布。
Display without digitizer stays black
I recently bought a series 5 with broken display glass. I was able to separate the broken glass and digitizer from the display succesfully.
At first I thought the display was broken after the separation since it stayed black. But at some point the battery died and suddenly the display showed the following image:
After charging for a while, the watch turned on and went into black screen again and stayed black.
I am currently waiting for the replacement digitizer to arrive, but I assume the series 5 is showing a black screen, when no digitizer is connected.
Can anyone confirm this behaviour?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you ever figure this out?
I have a friend who has a series 5 that works fine, but the screen has two scratches.
How hard was it to separate the digitizer from the LCD?
由完成的
添加一条评论
6个答案
最有帮助的答案
If this is happening, there is either something stuck in the screen connector, the LCD cables are damaged, or one of the pins on the screen is bent out of place.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Franqus, I am having the same problem. Removed the glass (and by accident the digitizer) and now there is no image....
Did you manage to revive your Oled display?
Thank you
这个答案有帮助吗?
得分 1
添加一条评论
My Apple Watch 5 was working fine. I took it off to take a bath and when I went to put it on my arm the display was black and showed the time only. I shows a red low battery but it was fully charged before. Any suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I have the same problem. Did the new digitizer help?
这个答案有帮助吗?
得分 0
1条评论:
Did you finalize fixed the display? Or just replaced entirely by a new one?
由完成的
添加一条评论
Same as @lucianolavigne . I stripped a part of the cable that connects the digitizer so I need to replace it. Can anyone confirm if the display should at least turn on if I remove the digitizer? I just want to see if it is working before doing/buying anything else.
这个答案有帮助吗?
得分 0
添加一条评论
Hi, i hv that series 5 with black display and time don't know what happened. Never dropped cracked broken or opened.
Anybody want ot for parts or hv a solution kindly hit me up. I'm frm Pakistan.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
franqus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,242
