MacBook Air won't turn on
So, looking for concurrence of a diagnosis from those who are WAY smarter than me! I’ve read similar posts on this topic, but none exactly like this situation.
Early 2015 MacBook Air suddenly shut down and wouldn’t turn on. Resetting the SMC and the PRAM made no difference. Connected charger is orange, and then turns green to signify a full battery (which it had). After removing the bottom cover and disconnecting the battery, the laptop will power back up and run and continue to run if I reconnect the battery and disconnect the charger. I can even put the laptop to sleep by closing the cover, and it will wake normally. However, if I connect the battery and shut down the computer, I cannot restart it with the power button. I should mention that I believe the charge LED remains green if disconnected from the battery.
My guess is that it’s a bad keyboard, and it would be easiest to replace the whole top assembly. Do you think I’m right in this?
Thanks in advance for your wisdom!
Cz
3条评论
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
Hey Dan- so sorry for the delay. My flight got changed yesterday, and I haven’t had a chance to get back to the MacBook Air. I’ll reply with the information you requested ASAP!
由 John 完成的
Hey Dan-
I posted that image at the end of the original question.
由 John 完成的
