跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Buds+ 真无线入耳式耳机的维修与拆解信息。于 2020 年 2 月发布。
Galaxy Earbuds Plus Battery Replacement
One of my earbuds isnt suddenly working, so I decided to open both of them to switch their batteries. Turns out, the battery of one of the earbuds isnt working anymore. i want to replace it but the batteries available here in ifixit is only for the galaxy earbuds. i need the plus one. Anyone here knows where i can buy one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
At 59 seconds into this video that battery type number for the Earbuds+ can be seen.
It’s a ICR1454S coin cell battery.
Searching online using the type number only gets results for an ICR1454 battery not the “1454S” .
I don’t know if they are the same or not but this Varta coin cell datasheet (see p.32) gives the specifications for the ICR1454 battery. There is no mention of the ICR1454S. Perhaps it is a later type.
Check what type number is printed on the battery that you have and search online using the battery type number only to see if there are any suppliers.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
1条评论:
The Verta Coin Cell should work fine. I am assuming the s just stands for the Samsung variant, because the under side of the battery in the Ear Buds has an edge coating which might act as an insulator or a guideline.
As long as the size, contact (+/-) areas, type (Lithium Ion), and voltage (3.7v) are the same the battery should work.
完成的
添加一条评论
添加你的答案
Carl Jenry Chua 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 1,834
