跳转到主内容
加入维修社区 - 创建账户
Lenovo Legion 系列游戏笔记本电脑的维修指南和支持信息。
FnLock Led indicator is not functioning
Although the FnLock key is functioning there is a spot in which a light is supposed to shine when FnLock is on and it does not. I have tried reinstalling drivers, and am lead to believe this is a hardware issue.
Lenovo Legion 5-15
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
9条评论
Hey I kind of have the same problem. Did you manage to get it fixed?
由完成的 分享
I’m having a similar issue. I first noticed that the Fn lock indicator light wasn’t turning off when pressing Fn+Esc. I decided to check for system updates and found a BIOS update (FSCN13WW) was available. While attempting to install it, the process failed on boot with an error message saying that the BIOS was incompatible with the system. Lenovo Vantage shows that it was successfully installed, however.
After that, the Fn lock LED does not come on although the Fn lock is being activated/deactivated. Num Lock led works fine.
由完成的 分享
I had the same problem and tried searching for a solution. Try to run the LenovoUtility app. if not installed, install it from the microsoft store
由完成的 分享
I first tried installing it from the lenovo website; that did not work. . Installing the vantage app from the microsoft store fixed the problem.
由完成的 分享
@gabriel.cabigting installing the LenovoUtility app fixed everything. Thanks a lot!!
由完成的 分享
显示更多的4条评论
添加一条评论
4个答案
最有帮助的答案
Lenovo Utility from Windows App Store fixed the Light
这个答案有帮助吗?
得分 3
3条评论:
Yasss,,.. it works for me, on my lenovo legion 5.
Thanks Andy!
https://www.microsoft.com/en-us/p/lenovo...
由完成的 分享
my lenovo ideapad gaming function lock indicator and microphone kill button was not working, so i searched google and came through this page , got known to download lenovo utility , and yes it worked. thanks andy sledge
由完成的 分享
how it works?
由完成的 分享
添加一条评论
[SOLVED] Download Lenovo Utility
这个答案有帮助吗?
得分 3
添加一条评论
Hi
I actually have the same issue. I just got the Lenovo Legion 5, and the FnLock lights do not turn on when I press Fn + Esc, but when I go to Lenovo Vantage and turn on the keyboard top row function, the lights do turn on and off.
Before this, I had an issue with the backlight not turning on when I press Fn + Space Bar and this issue was fixed by updating the system with a BIOS Update in Lenovo Vantage. Hopefully, a new update will come in the near future so that the lights can come back on.
Thanks.
这个答案有帮助吗?
得分 1
添加一条评论
I Success Solve the problem, just run lenovoUtility on your laptop, and it’s solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
newfangled cypher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 45
总计 7,244
