跳转到主内容
加入维修社区 - 创建账户
HP ProBook 650 G1 是一款于 2013 年发布、针对专业人士设计的 15.6 英寸商务笔记本电脑,旨在平衡性能、耐用性和性价比。它提供多种配置,既能满足日常办公需求,也能应对要求更高的应用。
Help identifying part attached to power button assembly.
Help identifying part attached to power button assembly a black box with this info "Veco CZ145"
Has a flat 4 ribbon soldered to power board and a 2 wire black/white connector to motherboard. It is a part associated to power. Thanks
HP Probook 650 G1 motherboard 744016-001
UPDATE
Problem solved thanks to member “jayeff”
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @gensin ,
Don’t know the answer here’s an image from the schematics for the motherboard, (I think they are the correct schematics anyway) showing the power button board circuits. I’ve highlighted component CN9200 which fits the description that you’ve provided.
(click on image to enlarge for better viewing)
Searching online using the information written below the component i.e. ACES_50503_0044N_001_4P gives no results as to what it is other than it is also used in other makes of laptop computers. Unfortunately there is no parts list as such, associated with the schematics describing each component, only what is written on the circuit diagram.
I’m wondering if it is a sensor (switch?) for the lid and signals when the lid is open and shut so as to either place the laptop in sleep mode or to turn off the screen when the lid is shut, depending on the power settings etc. Just a thought.
If it is the lid sensor (check if lid functions when set in advanced power options work e.g. sleep when lid closed, turn on when lid opened etc, if not, then it may be easier to get a replacement power board than to find the elusive part. Here are the part numbers for the power board taken from the hardware maintenance manual (see p.86)
Power button board (includes cable) For 15.6-in. models 738701-001 For 14-in. models 738399-001
If you search online using the appropriate part number only you’ll get suppliers of the part
Hopefully this may be of some help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cruz Cruz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 656
