跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 850 G2 发布于 2015 年,是 850 G1 的更新机型,配备了更新的处理器以及可选的触摸屏。你可以在此找到维修指南和详细信息。
How can I reset BIOS password?
I have purchased a second-hand laptop and found the BIOS is password protected?
Is there a way to reset/remove BIOS password on this particular laptop?
I have tried removing CMOS battery but this has no effect (I believe BIOS password is held in NVRAM on this model).
HP say the only way to remove the BIOS password is to replace the motherboard which I am not willing to do as apart from being able to access the BIOS, the laptop is running fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Take it back for a refund.
由完成的
remove bios password hp elitebook 850 g2
由完成的
Not sure why TB rep claims it costs more than the laptop to do this, In reality, it costs about as much as lunch. Get this off amazon HiLetgo CH341A STC Flash 24 25 EEPROM BIOS Writer USB Programmer, it's 7 dollars. Then Email me or reply back here and I will instruct you how to dump the BIOS, and I can tech you to remove the password or I can do it for you. It's really not that hard. I've done hundreds of this very model.
由完成的
添加一条评论
4个答案
已选择的解决方案
Replace the BIOS chip, or download a dump of the BIOS chip and delete the password. I did this on a laptop HP EliteBook 820 G3.
这个答案有帮助吗?
得分 1
添加一条评论
You can't…
You need tools that cost more then the laptop to rewrite BIOs and then you need software versions match for firmware and INtel ME or it won's boot plus the DMI tool.
Long story short, forget about it! Return or use as is…
这个答案有帮助吗?
得分 1
1条评论:
Just purchase a bios chip off ebay, and replace it, but you should have some soldier experience.
由完成的
添加一条评论
Just read this and it gave me a glimpse of the future of bios support from computer manufacturers. Looked pretty depressing too!
HP-EliteBook-840-G2-bios-password-reset
这个答案有帮助吗?
得分 0
5条评论:
Thanks for the reply (and the link) but HP say they will only supply a SCM.bin file for machines that are still under warranty. They say the only option after this is to replace the system board which seems a bit OTT as the system does not have any other fault.
由完成的
What is the serial number of the unit?
由完成的
S/n: is 5CG6195QF3
由完成的
Hmm, I tried to see if HP's website had anything to offer based on that serial number and no luck. I think you may have bought a pig in a poke. Have you any luck contacting the seller?
由完成的
My Elitebook is still under warranty and they will not give me the scm.bin
由完成的
添加一条评论
HP bios bin file need to modify with LBE++ Software. It will remove the Pa$$word
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darrell Haslam 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 49
总计 12,680
