跳转到主内容
加入维修社区 - 创建账户
Polar 生产的智能手表维修指南。
MicroUSB for Polar A370?
The microUSB connector of my my Polar A370 is broken.
When I’ve contacted Polar Support asking about how to adquire as spare, the only option they do is sending the wristband for a repair, which will be expensive cause is not in guarantee period, and really I know how to replace the conncetor.
So I’m looking for the conector, and any information about will be well received! (:
Thanks and regards!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
The issue is pins of external side of the connector are completely ‘destroyed’ , and charging is not possible
Internal side including flex seems in good condition. Really I don’t have skill or equipment to solder this kind of components, but inside A370 main elements are easy to manipulate cause are inserted, not welded.
I’ve thought about a faulty watch, but I didn’t find any option. Probably A360 and A370 connectors are identical, but I’m not sure.
完成的
I have a Polar a370 too and I was wondering how you got your watch open. I took out the screws but I can’t seem to open it.
完成的
Cause it's sealed by means of any silicone or glue for being water proof, any lever and force is required
完成的
I was able to open up my Polar a370, but I'm having problems getting it back together. Have you been able to get your watch back together?
完成的
I didn't try, due to I didn't find a replacement for the USB connector, I couldn't charge it and died...
完成的
添加一条评论
1个答案
Wow, this connector sure is special. What seems to be the issue with the connector?
If the flex is torn, it might be possible to solder it (deeper soldering skills required). Other than that, getting a faulty watch of the same kind as a donor might be a way to go for you?!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fernando 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 885
