跳转到主内容
加入维修社区 - 创建账户
Kodak EasyShare Z740 拥有出色的功能组合、易于使用的控件和强大的变焦功能,是那些寻求简单相机又想进一步提升摄影水平的用户的理想选择。
Formatting SD Card Error
Anytime I insert an SD card into this camera, the screen states “Memory card requires formatting”. Out of the two options displayed, I would select continue, and it would procees to load, then return to the screen that said the card requires formatting. If i choose to cancel when the screen says “Memory card requires formatting”, it says “Memory card cannot be read —(please format memory card or insert another memory card.)”. I’ve cleared the card completely and even tried a brand new card, as well as a micro SD with an adapter. Both cards are 32 GB; please help, i really want to take vintage photos with this camera!!! ☺️
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Has the 32GB SD card worked in the camera before?
If not given that it is old camera technology from ~2005 it may be that the 32GB SD Card is too great a capacity for the camera to recognize.
The camera’s user manual storage capacities are quoted in MB (Megabits) which is 1000 times smaller than GB (Gigabits) , so try using a 2GB or hopefully a 4GB or 8GB SD card and check if one of those works. According to the manual you can format the SD card in the camera if it is recognized that is.
这个答案有帮助吗?
得分 3
1条评论:
It could also be that the card is too epic for the camera.
wait. oh wait that's what this answer was saying. ohhhhhh
由完成的 分享
添加一条评论
heyy i had this same problem and got it fixed.
Its very simple, all you gotta do is format the card to NTFS (should work with MacOS and Windows) I think mine was exFAT and thats why it didnt work.
Hope this helps! (:
这个答案有帮助吗?
得分 3
5条评论:
I’m having this same issue. Can you please explain in a bit more detail what that means exactly? :)
由完成的 分享
I am also having the same issue, please let me know!
由完成的 分享
Just right click the SD card in your filepath and hit format. but this doesnt seem to work for me... I wonder if we had the filepath and could format for the camera if that would help. If any of you knnow the folder names and file path lmk
由完成的 分享
Just curious, what SD card size did you manage to get working? I know 2GB works but I'd like to get the largest size that works with it, if possible. Thank you all!
Edit: I realized this camera is only compatible with SD cards, and not SDHC. This means its maximum capacity would be 2GB, I believe.
由完成的 分享
Tried your suggestion using my laptop.... does not work.
由完成的 分享
添加一条评论
添加你的答案
Liz Murphy 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 164
总计 31,028
