跳转到主内容
加入维修社区 - 创建账户
SL 系列起亚 Sportage 于 2010 年 4 月在亚洲和欧洲市场发布,随后于 2010 年 8 月进入北美和中美洲市场,作为 2011 年款车型。
Door ajar sensor replacement
How do i replace the door ajar sensor in my 2013 kia sportage, do i just unscrew the existing and replace or do i need to take off panel?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Proplam when open the panorama
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @cinlou111
Looking at the images of the door switches from the 2012 repair manual, (hopefully the same as the 2013 model) you just unscrew them and gently pull them out.
Be careful as there is power going to the switch so watch that you don’t accidentally blow the fuse if the wiring touches the body. Find the fuse (inner fuse panel dashboard - Room LP fuse) and remove it before removing the switch
Depending on the length of wire attached to the switch, don’t let the wire go back into the cavity when you disconnect the switch, it might be awkward to get it out again ;-)
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cindy H 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 31
总计 2,169
