跳转到主内容
加入维修社区 - 创建账户
苹果第四代智能手表,带有可选的蜂窝网络功能,于2018年9月21日发布。
Power button is stuck
I have an apple watch series 4 that has the power button stuck pressed in. I had a protector cover on it that I never removed and it may have built up dirt and grime over time. I tried cleaning it around the edge of the button with a toothbrush and some water to no avail. When I connect the watch to the charger the apple icon comes on for a few seconds but then turns off due to the power button being stuck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
+1 for rinsing for a minute under warm water, which worked for me.
Context: after several days of swimming in salt and fresh water over the course of a week, after the last dip, the power button seemed to be stuck, going into Emergency SOS mode over and over again. After a reboot, the button was still stuck, so it could not boot: it would show the Apple logo for a few seconds then reboot again. Washing under warm water and clicking the button repeatedly fixed it.
这个答案有帮助吗?
得分 3
添加一条评论
From others who have had this issue, it looks like you can carefully rinse it under warm (not hot) water from the tap. Maybe this would remove whatever is causing the stick?
这个答案有帮助吗?
得分 2
添加一条评论
I had this exact same problem after using the SUP case. I found a local iPhone repair shop that was able to replace the power button and the clicking mechanism beneath it and the watch is like new again. Hopefully you can find someone willing to give it a shot!
这个答案有帮助吗?
得分 2
5条评论:
The same thing just happened to me with a Supcase. What did they charge for the repair.
由完成的 分享
Same here with the Supcase I wouldn’t recommend the case for that.
由完成的 分享
Same! SUPcase! Dang!
由完成的 分享
Same thing is happening to me. Also had in a SUP case.
由完成的 分享
The repair cost about 50 bucks I believe. Unfortunately maybe a year after that the battery started to die almost immediately and I had to get a new watch anyways.
由完成的 分享
添加一条评论
添加你的答案
Freddy Gomez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 64
总计 17,828
