My device is not charging
My Versa 1 is not charging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论:
This question has a serious lack of information. How do you normally charge the device. I have a different smartwatch and I have to remove one part of the wristband and then plug the device into a charger. I did a little research on this and the consensus leads to the charger being the most likely issue. Contact Fitbit. https://help.fitbit.com/?l=en_US&cu=1&fs...
完成的
@manjunath.kalose.rao Check your charging port.
完成的
添加一条评论
