跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 个问题 查看全部
What means Greasy yellow fluid in the valve cover air vacuum hose?
i have a 2006 nissan altima 2.5l SE. I was changing the starter motor. When a removed the vacuum hose between the valve cover and the intake was some greasy yellow fluid in the hose. I thinh oil mixed whit antifreeze? What that means? And how could i fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
We need to see what it looks like, and where it is. Sounds like a head gasket issue since yellow usually points to that.
I took a shot in the dark to put an answer out, but I aimed in the direction with the best chances.
完成的
You can get a head gasket tester that can check if it has carbon monoxide in the cooling system to verify. You can also see if you have a cylinder missing which can tell you which cylinder has the leak.
完成的
@barriphone It's almost certainly the head gaskets and other seals. Classic Nissan defect post Renault. Individual testing is redundant - even one leaking is still a leak.
The only individual test worth *doing* is a cylinder pressure test.
完成的
It will probably have a cylinder misfire code in it and what cylinder it is.
完成的
添加一条评论
2个答案
最有帮助的答案
Check for a head gasket leak - these 2000-present Renault Nissans regularly blow out hed gaskets once they start to run up mileage that is just broken in on a Toyota or Honda. You can get a kit on Amazon to confirm, but I wouldn't be surprised with a Renault Nissan.
We don’t know which engine you have, but the risk goes up at the 90k+ mile range and gets worse as you near 100k. You can find a head gasket kit here (all seals and bolts). To do every seal requires the engine to come out, so you may need to defer this to a mechanic due to bad Nissan design. Valve body shouldn't be TOO hard. Be warned for a lot of Nissan/Renault engined the head gasket is a known PITA job.
这个答案有帮助吗?
得分 1
添加一条评论
It water or antifreeze is the oil. It sounds like a blown head gasket or a cracked head.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lorospeleo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 294
