跳转到主内容
加入维修社区 - 创建账户
2010 年发布的一款 15.6 英寸屏幕的通用型笔记本电脑。
Sound system is broken
My laptop sound won't work. I've disassembled the device and I strongly believe there's a problem with a diode or transistor, and since all sound hardware seems to be on board, I'm probably going to need to replace some of these small parts. Does anybody know of the schematics for this laptop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
If your computer is not making any sounds, see the Acer Aspire 5253 Has Volume Control Problems problem page for possible causes and solutions.
Here are the schematics for the motherboard, found from this website.
Go to p.27-28 to find the audio circuits.
Have you checked that the headphone socket is OK and connected properly?
When headphones are plugged into the laptop an internal contact in the headphone socket signals the audio codec IC on the HP_Plug# lead (see p.28) to switch the audio away from the main speakers and connect it to the headphone socket. It may be that the headphone socket is faulty and that the audio output is being permanently directed to the socket but it just doesn’t get through it to the headphones. Worth checking first anyway, if only to eliminate the possibility.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel Bozza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 507
