跳转到主内容
加入维修社区 - 创建账户
苹果出品的高性能平板电脑。
2019 IPad Pro charging issue
Hello,
I have a 2019 iPad Pro that I bought 6 months ago. Up until this point I have not had a single problem. Today I realized that it had died so I plugged it in to charge and left it. I went to check on it a couple hours later and the red battery light was flashing. I unplugged it to see if it would cut on and nothing happened. I plugged it back in and the red battery light came back up then went away repetitively. This has been constant for 30 minutes now and the iPad will still not come on. Does anyone have any advise as to why this is happening?
Note: I have tried several different cables and adapters along with plugging it into a computer with the same result.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Have you used aftermarket charging cables? It sounds like you used a aftermarket charging cable that wasn't MFI Certified and it can cause voltage spikes and damage the tristar ic which is the chip that controls charging and data transfer. It will need microsoldering repair. It's probably under warranty and they will probably warranty but if it cannot be turned on you won't be able to retrieve your data. Apple won't retrieve data if the unit will not turn on. They usually swap your defective unit with another refurbished one.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the advise. I do use aftermarket chargers when I’m at work. It worked perfectly fine the other day and then today was when this happened. Hopefully it’s covered under warranty. You wouldn’t happen to know how much it would cost to fix it if it wasn’t covered?
完成的
添加一条评论
If you have a Mac download Coconut Battery and install it.
Plug your iPad into a USB port and run the APP and select the iPad. Post your results so we and take a good look at the iPad
https://coconut-flavour.com/coconutbatte...
这个答案有帮助吗?
得分 0
2条评论:
I do not own a Mac unfortunately
完成的
@destin7410 Phone a friend. Here are PC alternatives:
https://alternativeto.net/software/cocon...
完成的
添加一条评论
添加你的答案
Destin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 197
