跳转到主内容
加入维修社区 - 创建账户
发售于2016年11月,PS4 Pro升级了硬件,使其能够支持4K游戏并提升了PSVR性能。
Help finding HDMI SMD capacitor values
I recently took in a WLOD PS4 pro and was attempting my first ever HDMI IC chip replacement. I successfully removed the chip, but accidentally nudged these two (what I think are) SMD capacitors off the board and lost them. Does anyone know what size or better yet where I can find these components?
The motherboard model is an NVG-004.
It was suggested I try taking components from a PS4 slim, but the slim model’s components are larger than these, and I have yet to get access to a junk PS4 pro board.
Any help would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
i measure both of them the big one is around 5.3μf and the small around 100nf
is just bypass caps for the power supply of the hdmi amp, it will be fine if you place not exactly the same values.
like one five micro farads and one three hundred nano farads …
这个答案有帮助吗?
得分 3
2条评论:
Thanks man! I’ve been sitting on this board for a while; totally stumped on what to do with it next. I’ll try some different caps from a donor board and see where that gets me.
由完成的
Mario, just wanted to let you know you've helped another person who stupidly undertook trying to fix an hdmi port and had the same issue. Very, very much appreciated!!!
由完成的
添加一条评论
I will get back to you later today as I have a PS4 Pro board sitting on my table.
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
Can you estimate the size of the capacitors? So I guess the big 1206 and the small 0603
Best Regards
Christoph
这个答案有帮助吗?
得分 0
1条评论:
I spend hours searching a pcb at my lab... well, no! the big one is 0603 and the small 0201. so you need microscope or magnifying lens. solder the small first i suggest with a bevel tip this board have a lot of thermal capacity... if you want to avoid the small you could try to solder a 3.3uf 0603 and a 2.2uf 0603 in parallel at the big ones pads. otherwise it might work without the small one at all but im not sure about how stable it would be...
由完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 33
总计 2,174
