跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
iPhone X not charging after battery replacement
I successfully replaced my battery with ifixit battery. When i turned it on it was at around 50%. I drained the battery to 10% then tried charging it, i saw the charging icon then left it alone. I checked back on it after an hour and it’s still at 10%. I used an original ipad charger i bought from an apple store with the cable tha came with my iphone x. I also tried using my iphone 11 pro max charger and cable and still does the same. How do i fix this. Thanks in advance
Update (06/19/2020)
Fixed it! I guess I got a bad replacement battery, contacted ifixit and they sent me another one. Replaced it again and so far it works great
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
Try the old battery and see if it works then. It's a possibility that you got a defective battery. You can also try unhooking the battery and letting it reset. There is a very small possibility that you have a bad tristar ic and it could stop it from charging.
这个答案有帮助吗?
得分 0
2条评论:
Unfortunately, i have disposed of the battery. Now, i have tried unhooking the battery and hooked it back it in but it’s still not charging
完成的
Allan is correct, most likely your battery is defect.
完成的
添加一条评论
添加你的答案
William Chua 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 24
总计 2,503
