跳转到主内容
加入维修社区 - 创建账户
型号 A1312 / 2011 年中期 / 2.7 及 3.1 GHz Core i5 或 3.4 GHz Core i7 处理器,型号:iMac12,2
iMac iSight camera to USB Pinout
Hi all,
I deconstructed my iMac and made it into a functioning external monitor after it broke.
I want to re use the iSense camera by making it a USB device. I have heard of people soldering the cables onto a USB for use. The issue is, there is 7 wires and I am not sure which wires to attach to the USB as they only have 4 connections. I have attached an image.
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Is the camera 3,3V or 5V ?
由完成的
Hello, does anyone know how to do it with 2017 imac facetime camera? Its on 20pin flex cable. I cant find pinout or board view anywhere. Camera module 821-2477-A and board 820-00609-A
由完成的
添加一条评论
4个答案
已选择的解决方案
I also have a 2011 27" iMac, but clearly different color wires.
I reverse engineered Virtual Drivers video to get the pin order, not the colors since those change even between the same models.
For my 2011 27" iMac 7 wiring is as follows (camera facing you, looking at the QR code, from left to right):
wire 1 black - x
wire 2 purple - x
wire 3 brown - x
wire 4 black - black
wire 5 grey - green
wire 6 green - white
wire 7 blue - red
这个答案有帮助吗?
得分 4
6条评论:
thank you finally a pinout that works!
由完成的
Thanks for this. This worked for me. All of the suggestions which rely on colours aren't helpful. I have 3 - 2011 iMacs and each one has different coloured wires! I think the key is (as you said) wire location relative to the camera on the plug. The last 4 wires (away from the camera when plugged in) are the only ones needed. Also, after stripping the cable, I only had 6 wires. The thick Black #1 wire wasn't in there. Just to demonstrate, here are my wires used.
Plug > USB
#4 (Brown) > Gnd (Black)
#5 (Grey) > Data +ve (Green)
#6 (Purple) > Data -ve (White)
#7 (Blue). > Power (Red)
由完成的
Will this work with a iMac 21.5" 2014?
由完成的
@poesis3d Its works for me too :-) Thank you very much. My iMac 2011 27 has this color on the cable.
由完成的
@poesis3d it also works for me. In my case, it is an iMac mid 2011 21.5”.
由完成的
显示更多的1条评论
添加一条评论
To connect iMac iSight camera to a USB connector
Camera wires to USB cable wires
  • Black - Black
  • Blue - Red
  • Brown - White
  • Purple to Green
The first two are power, the last two is the data output.
Update (06/19/2020)
Are you sure the camera is working?
Here’s the other side connection verify the lines
PP5V_S3_Camera is the positive power line (Red) and the frame ground (Black) is the negative side. Do you measure power?
这个答案有帮助吗?
得分 3
8条评论:
Thanks for your reply! So apart from these 4, I do not need to connect the other wires?
由完成的
They are the microphone lines (analog) unless you have a DAC to convert the signal you can't use it.
由完成的
Awesome, you're the best man. Very greatful
由完成的
Hi mate, I tried connecting it in the way you said but got nothing!
由完成的
Hi Sumeet, Did you ever get the camera to work? My 2011 iMac's wire colors exactly match yours, which are different than Dan's, John D's and Virtual Driver's (video). I've tried all these combos and nothing works.
由完成的
显示更多的3条评论
添加一条评论
You can find the correct pin out of the board and just match it to the standard USB Type A pins
https://s5.electrodragon.com/wp-content/...
There are two GND cables coming out of the cable. I used the smaller cable and left the big one alone (not connected)
Works like a charm. It took me a long time to find out the correct pins.
Hope that helps.
这个答案有帮助吗?
得分 1
添加一条评论
Can share which wires connect?
这个答案有帮助吗?
得分 1
2条评论:
Imac 2011 27inch isight camera to usb
usb to camera wire
black— blue
Red-grey
green - purple
white-red
由完成的
This worked for me!!! Thank you!!
由完成的
添加一条评论
添加你的答案
Sumeet Saini 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 104
总计 8,851
