跳转到主内容
加入维修社区 - 创建账户
Samsung Series 5 3G Chromebook。这款笔记本电脑配备了 12.1 英寸超亮高分辨率防眩光显示屏,非常适合网页浏览。
Galaxy Tab 3 10.1 shuts off...
When my power level gets below a certain level, if I plug it in to charge it, it just drops to 0% and shuts down.
I have limited experience with device batteries in these kinds of electronics, particularly Li-Ion. With tools if they over heat they;ll shut down and come back up in a few minutes. This is a genuine drain to 0%. Is it the battery, or something else? Any one?
And why aren’t tablets listed as an available device any where in the device list?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is it imprinting, like NiCads do?
It will re-charge with out a problem.
完成的
添加一条评论
1个答案
If it completely shuts down while plugged in, your charger might be bad. On Powe settings, the power plan might be shutting off the screen but the computer actually remains on until keyboard or mouse activity is detected. If this isn't the case, test the charger output. Your computer should indicate plugged in and charging . If not, the charger is bad and you need to get a new one.
If the charger is known to be good and it STILL doesn't charge your computer, kindly check out the post.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Norman Hendrikcson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 232
