跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Mower won't start unless I put gas in the spark plug well
I have a Briggs and Stratton 4-cycle, OHV, self-propelled mower. It is several years old, we just got it from a friend. It worked the first few times we tried, then just woudn't start. I changed the spark plug and air filter. Still nothing. Then I pulled out the spark plug and put a little bit of gas in the well. It started and ran like a champ for an hour while I finished the lawn. I believe this is a carburetor problem, but don't know for sure and I am a novice repair guy who wants to learn how to do all this myself. What do I need to clean/fix/replace, and how do I do it?
Thanks so much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I have the same issue. Fuel is not getting to the plug. The carb is perfect, I don't think a new one could be cleaner, fuel line is clear, bowl is filling nicely, needle and seat working, valves are good. I put fuel in the well and it started, ran a couple seconds and cut out. There's no solenoid on this carb. Help!!!
完成的
Gotta get fuel from the carb bowl to enter into the intake... Take bowl off, run a teeny tiny stiff wire (guitar strings work great) up through the main jet until you see it come out the top of the jet. Blow with compressed air if you have it.
完成的
I had cleaned the carb (removed, cleaned and reassembled) and made sure it was getting through. Eventually discovered the problem was the fuel, emptied the tank and put new fuel in and it goes great!
完成的
What makes a bubble leak out of the middle pin hole
完成的
添加一条评论
4个答案
已选择的解决方案
First off, I'd clean the carburetor. Take the bowl on the bottom of the carb off. You will see a float and a needle valve. Make sure the float moves and that the needle valve functions properly. Clean your gas line from the tank to the carb as well as make sure that your gas cap is vented, there are either a few holes in it or a washer underneath the cap. If it is not vented you will get a vacuum and fuel will not flow. Good Luck and I hope this helps.
这个答案有帮助吗?
得分 5
4条评论:
+ Good advice..
完成的
I cleaned my carb twice and it is still doing the same thing it will crank with fuel poured in cylinder and in inlet of carb but shuts down Replaced primer bulb Mower is 11 yrs old
完成的
I have the same problem, just wanted to ask if you ever found out what was wrong or if you found a fix for it? thanks
完成的
I have a Pulsar lawnmower the bubble is leaking gas threw the hole in the center of the bubble is it a bad bubble or is something causing it to leak
完成的
添加一条评论
i’m like you, in that i wasn’t born with a wrench in my pocket, but i wanted to know how to take care of things on my own. with average aptitude and a few tools, willingness to read and learn, and the internet, and you’re on your way. for me, no matter if it’s a washer or dryer, stove or frig, mower or truck, etc., it always starts with a model number. use it to do a search and you find diagrams and parts as well as troubleshooting guides and repair videos.
one thing i can tell you about small engines (these days) is that the carbs are crap. 85-90% of the problems i run into with small engines is carb related. your problem is very likely solved with carburetor service ( but don’t overlook first checking for other obvious problems, like a cracked primer bulb, etc.).
the answer provided previously is very decent, but assumes you know the language and/or are familiar with the components, which you may or may not be. understanding how a carburetor works or how to service one is not rocket science, but you’ll benefit greatly by reading up on it, first.
if you do get into such things, here’s a couple of thoughts- start by clearing the clippings, grime and grease, etc., from the mower, so these potential contaminates are eliminated. take a picture of the way things are assembled before you start, and at various points along the way, so you can be sure the way things are put back together. also, when you begin to take things apart, do so carefully, as it’s easy for these small parts (including springs) to get away from you and get lost, or at least hard to find. have some bench-top area with a couple of trays (for parts), carb cleaner, degreasing solvent, and some shop rags. you’ll be needing pliers, wrenches, sockets and screwdrivers, and an assortment of small gauge wires. having a compressor and air nozzle to be able to blow things out or off helps too.
finally, when cleaning the carb, bear in mind that in addition to other carb service aspects, the tiny ports the fuel flows thru are easily plugged with some kind of debris or deposit. use carb cleaner and spray all ports (be sure to protect your eyes and hands), and use the appropriate size wire to clear each port, then spray again, and (if you have compressed air) blow out. make sure each and every component is clean, and re-assemble things exactly as designed.
hope you find your problem and in the process get to learn some things, too. Good Luck!!
这个答案有帮助吗?
得分 1
添加一条评论
Spark plug well is flooding with gas won't start . What can I do to correct this?
这个答案有帮助吗?
得分 0
2条评论:
it is likely the fuel continues to leak thru the system after you shut off the mower. just how this is happening in your case depends on the mower design and features. please include mower manufacturer and model number for more help.
完成的
many things can cause this from bad rings to failing gasket even to a faulty carburetor solenoid. if you are not comfortable with small engines I would recommend you take it to an authorized technician.
完成的
添加一条评论
# If the mower has been sitting for awhile, consider the gas may be too old or contaminated with water.
  1. If you clean the carb, take the small brass piece (jet) out and poke the little holes with a paper clip to clean them. Make sure they are clear either by looking with a light or blowing through them. Poke the areas where the jet screws into. I use carb cleaner to squirt those ports and look for cleaner to then squirt into the carb throttle bore to ensure they are indeed clear.
  2. If the spark plug is dark and shiny, it is probably fouled. Either sand blast the electrode end until the insulator porcelain is fairly white or just replace it. If you have an old automotive spark plug laying around, don’t try to use that in your small engine. They are too long and even though they might not hit the piston, they will be in the wrong position to ignite the fuel. I know…..I tried them. Spark plug sand blasters are around $15……but you also need an air compressor.
  3. Take all air cleaner parts off until you can get to the carb so that you can see the buttlerfly flap move. Use the equivalent of an eyedropper to squirt some gas in the throttle bore. If you can crank it now and get some pops then it will eventually start. If it does start and keeps running, the carb cleaning and spark plug cleaning did the job. If it starts but won’t keep running even after several squirts of gas and restarting, the carb ports are either still clogged or the fuel line is clogged. Also, put enough gas in the tank to ensure gas is actually getting to the carb.
  4. An additional note. I was working on an Intek engine that wouldn’t respond to the primer bulb. I would push the bulb and smell no gas and the engine would not start. I took the assembly with the primer bulb off and noticed that the hole in the plastic piece with the primer bulb didn’t match up with the hole in the carb. The primer bulb passage was in effect closed off. I ended up making a special gasket with a passage for the hole in the plastic air cleaner piece to send air from the primer bulb to the hole in the carb and now it starts easily. This one is a mystery to me.
这个答案有帮助吗?
得分 0
6条评论:
Would you possibly have any ideas for my issue...? Fuel is not getting to the plug. The carb is perfect, I've cleaned it, I don't think a new one could be cleaner, fuel line is clear, bowl is filling nicely, needle and seat working, valves are good. I put fuel in the well and it started, ran a couple seconds and cut out. There's no solenoid on this carb so that's not an issue.
I serviced it after it stood a while so spark plug is new, oil is new, fuel is new, air filter is new. It doesn't have a fuel tap or primer bulb.
完成的
Hi mine has the exact same problem as yours. Carb bowl is filling up with fuel but not getting to plug. Only starts when I pour fuel directly into plug hole. Did you manage to sort yours out & what's the solution. Thanks
完成的
I got the same problem poor fuel in carb runs with out wont run let me no what to do ty
完成的
Any answers to this some one could post? Im in same boat, new carb,plug,fuel and fuel is in the bowl no issue there!
完成的
I had that same problem. I took it to the mower shop they replaced the carb and it started right away like a brand new one I’m very happy
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Seth 将永远感激不已
浏览统计数据:
过去 24 小时: 20
过去 7 天: 54
过去 30 天: 190
总计 60,162
