跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
Dropped my iPhone X. No cracks but display gone black.
I dropped my phone accidentally. NO CRACKS in glass and touch screen is working fine but DISPLAY gone BLACK. I’m receiving Notifications, calls and speakers are working fine.
what might be the problem?
Do you think my screen is damaged?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
There could be a few causes, the most obvious being the OLED screen could have damage underneath the glass that is keeping the screen from powering on and in this case you would need a display replacement.
Another possibility is it could be software related have you tried to do the soft reset of the phone by tapping volume up then volume down and holding the power button until the phone power cycles? I have seen a few instances where this happens and does fix the problem.
The only next step that you could take would be opening up the phone and reconnecting the display connections to make sure nothing came loose if that doesn’t work then you definitely need a display replacement.
这个答案有帮助吗?
得分 1
添加一条评论
It sounds like you need a new screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thriven Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 44
过去 30 天: 185
总计 6,124
