跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 13'' late 2012 does not charge after water damage
Hi,
I spilled water on my macbook and now it doesn’t charge. However is does work when plugged in. I took it apart and cleaned everything. I noticed that the water damage indicator on the magsafe port pcb is red. I am wondering will replacing this part help? My guess is if it was broken the motherboard would not receive any power at all. Whereas now it is working from the wall.
Thanks for the answer.
UPDATE:
I was able to take it apart again and clean it with alcohol thoroughly and now it is charging. See screenshot below
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The water damaged your logic board and/or the battery its self. Lets see if we can get a better idea what needs repairs, install this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片
In addition lets run the onboard diagnostics, restart your system and press the D key let us know what the error message that comes up.
Update (06/08/2020)
OK, you are on borrowed time with your battery! You have 1105 cycles while the battery is only designed at best to go to 1000 Determine battery cycle count for Mac notebooks
Lets give that a try first! Here’s the needed part MacBook Pro 13" Retina (Late 2012-Early 2013) Battery and here’s the guide to put it in MacBook Pro 13" Retina Display Late 2012 Battery Replacement.
After you have let the system charge is it working better?
Replace a 6600 mAh battery compatible with MacBook Pro 13" Retina (Late 2012/Early 2013). 74 Watt Hours (Wh), 11.21 Volts (V).图片
产品
$79.99
MacBook Pro 13" Retina Display Late 2012 Battery图片
指南
难度:
困难
30 minutes - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
3条评论:
Hi,
Thanks for your answer. I took it apart one more time and did a more thorough cleaning of the whole logic board with alcohol and that did the trick. Now it is charging. Howerver it says that it is charging with ~22 watts. it fluctuates between 20 and 29 watts. Is that normal?
Screenshot attached.
Thank you very much,
Abe
完成的
@abrorhon - Don't see the screenshots? Once in the media tool bar you need to insert it.
The charging rate is dependent on the batteries temp and the level of charge it needs. Basically, its linear and is lowered when the temp of the battery is too warm.
完成的
@danj Hi Dan,
Screenshot should be up now. Thanks for your help.
完成的
添加一条评论
添加你的答案
abrorhon.ahmedov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 79
