跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Why is my ecently used apps button not working?
Dropped phone in toilet so I put it in a bag of rice for 2 days. After charging everything worked except my recently used apps button so i tapped it multiple times and also restarted my phone. This did not work but it started to flip between all my apps opened so again i restarted my phone. None of that was working and so I did a factory reset and it still flips between my recently used apps and home screen. What should i do? I am at limited resources as well. Anything to do at home?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
此回答最初是针对另一个问题
You can try taking a apart and cleaning the corrosion that is inside. What a few videos on how to do it. Putting a phone in rice is a myth and does nothing except possibly getting a piece of rice stuck in the charging port. Don't try to remove the screen from the frame unless you are going to charge it because you will damage it. But if you need to change the screen buy one with the frame already attached.
这个答案有帮助吗?
得分 0
添加一条评论
Hi @harleyjos
Water and electronics and electricity are not a good mix.The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components. The corrosion is ongoing until it has been properly cleaned away
Rice does not solve the problems caused by the corrosion Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to reduce any further damage
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. You will also have to remove any shields that may be covering the CPUs etc as water may have got in under them as well causing corrosion to occur there.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy S6 guide, which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 36
