Xbox 360 dvd/cd drive issues
Hello, i am trying to resurrect an old xbox 360 which was manufactured in 2007, initially it was over heating so i have taken it apart and added new thermal paste to the chips on the motherboard and with that the xbox is turning on without any RROD. Now my issue is that the CD/DVD tray will not open/close or read any discs even if i manually open the tray and insert a game disc. i have attempted to open the drive using the push button as well as giving the open tray command after the console boots up. i have seen several videos where people have said to open up the drive and perform some cleaning maintenance however that has not helped my case. I have taken a few screenshots and a small video to show what the drive is doing. I see that the laser light comes on and stays on for the full duration, not sure if that is normal? Has anyone experienced this issue before and if so, what did you do to fix it? do i need to just replace the whole drive and do the whole pcb swap or can i replace few internal parts within this drive to get it working again? thanks for your input
Does anyone know if i can use dvd reader from xbox 1 in xbox 360
由 Alan Cribbet 完成的
