跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
HDD data recovery with a Liquid Damaged Logicboard
My buddy spilled something on his MacBook. He took it to a shop and after a few weeks they returned it to him and say they couldn’t do anything. I took a look for him and there was a pretty good amount of corrosion around the usb-c ports. Some simple troubleshooting by shooting for power at the 2R7 inductor with the usb-c charger plugged in and got 0 volts. From what I was able to find online, it seems the charging circuit is most likely fried. My buddy only wants the data from his HDD, but again, it would seem there is no real easy way to do it without getting a working 2016-2017 MacBook Pro. Am I missing something here? Is there anyway to recover the data without a working MacBook Pro? Also, any tips on what could be fried and what I should check? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@munkeyjoe you have removed the board to clean the corrosion from both sides? What 820-XXXXX is your board? Where else did you check for power? You tried to use the power on pads to start it? Post some pictures of your board (both sides)that are a bit more focused.
完成的
@oldturkey03 - Sadly the newer 2016 & 2017 Fn models don't have exposed power pads. The area effected is around the Thunderbolt 3 ports.
完成的
I did remove the board nothing got underneath it and I haven’t checked for power anywhere else really I’m just trying to get the data from his HDD for him he, Apple told him he would lose his data if he takes it to them.
完成的
@munkeyjoe what board number is this? You got to test more than one inductor to find out where (and if) there is a short
完成的
添加一条评论
1个答案
最有帮助的答案
I think you need to ship out the system to someone with the deeper skills and needed parts.
Think of it like doctors,you go to your primary physician for a check up, clearly their skills are diagnostic and deal with simple issues.
You go to a hospital to have your appendix removed when it gets infected. But, its likely they don’t have the deeper skills to handle cancer.
This is where a specialist is needed! Thats the case here!
Where are you located country and nearest city?
Update (05/29/2020)
For reference here one option for a logic board: 13” MacBook Pro - Logic Board, 2.0GHz i5 8GB Apple P/N 661-05073 - Used
这个答案有帮助吗?
得分 1
4条评论:
Makes sense and that is probably what he will do. I live in Japan, we should have some places nearby as soon as the start reopening everything out here.
One question, can you swap just the logic board out? Will everything work or are some accessories married to the logic board like the home button on an iPhone 8?
完成的
Sure replacing the logic board will work! Then Transfer the SSD to it.
完成的
Data recovery on the 2016 requires a special rig setup, usually sold only to Apple Stores and ASPs.
完成的
@mayer The Touch Bar models the Fn models still have a removable SSD! Solid state drive for Late 2016 and Mid 2017 MacBook Pro without Touch Bar
完成的
添加一条评论
添加你的答案
Joseph Stratton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 178
