跳转到主内容
Oppo 手机维修指南。
395 个问题 查看全部
My phone is oppo a3s, wont turn on nor charge
My phone is oppo a3s, I was charging it because it only had 1% battery left, then the battery went to 0% but it was still on, afterwards it shut down and I tried to charge it and won’t turn on. I followed the instructions to press the volume up and power button at the same time to turn it on and it did but displayed a red lightning symbol, so I charged it until morning. I tried turning it on again but it won’t! Pls help me solve my problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
i lův piglĕts ØwØ  the very first thing you want to do is to check your charger. Make sure that it is working. Next check your connector and make sure that there are no broken pins, lint etc. obstructing it. If all that looks okay then go ahead and replace the battery with a new one. then re-evaluate. If that does not resolve your issue you may have problems with the charging port or the charging circuit on your circuit board. Again start with your battery because if nothing else it will provide you with a known-well starting point for further troubleshooting. Use something like this video to work on your phone
这个答案有帮助吗?
得分 0
添加一条评论
Try to clean the charging port if this doesn't solve your problem then go for replacement
How to fix oppo a3s charging problem
Didn't know about turning on problem but I was facing charging problem and now my problem is solved.
这个答案有帮助吗?
得分 0
1条评论:
Oppo a3s chalu nahi ho raha he
完成的
添加一条评论
添加你的答案
i lův piglĕts ØwØ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 83
总计 6,583
