跳转到主内容
加入维修社区 - 创建账户
这是联想 ThinkPad X1 系列中的第 1 代二合一翻转本,配备 14 英寸触摸屏,并附带一支手写笔。于 2016 年发布,型号为 20FQ00****
Why my touchscreen is no working?
Touch screen is not working, could you please help me out to fix the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
i’ve got the same issue tried everything possible x1 carbon 4th gen
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @vnod ,
What OS is installed in the laptop?
Go to Device Manager and check if the touchscreen is OK.
If you have Win 10 installed, right click on the Windows Start button on the left side of the Taskbar and click on the Device Manager link.
When is Device Manager, scroll down to Human Interface Devices and click on the > symbol to the left to expand the list.
If the HID - Compliant Touchscreen entry has a red cross next to it, right click on the entry and select Enable and check if the touchscreen works
If the HID - Compliant Touchscreen entry has a yellow exclamation mark next to it, right click on the entry and select Update driver software and follow the prompts. The laptop has to be connected to the internet for this to work though. Once the drivers have been updated,restart the laptop and check if the touchscreen works
If there is no fault symbol next to the entry, right click on the entry and select Properties > General and view the status of the touchscreen in the Device Status box. Does it say This device is working OK
这个答案有帮助吗?
得分 2
3条评论:
hi, mine has no HID Compliant touch option there. my touch just stopped working
完成的
@Koranj Scrap
What is the model number of the laptop?
Try selecting Device Manager > View > Show hidden devices and see if it it then shows up anywhere in Device Manager.
If not also look in Mice and other pointing devices or perhaps in "Other Devices" if there is such a category in your Device Manager list
完成的
after going to task manager, disabling and enabling my HID-Touch screen and my screen touch is still not working
完成的
添加一条评论
yo tengo un problema en mi lenovo thinkpad x1 yoga gen 4, prendo el dispositivo y funciona todo muy bien, pero al momento que cierro la tapa, y la vuelvo abrir, comienza hacer toques falsos, eso me pasa con win 11 pro, no se si sea por el sistema operativo, pero me quiero pasar a win 10a ver si se soluciona
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vinod Kumar R 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 24
总计 4,476
