跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
computer cant find iPod
I broke my screen and decided to buy a parts one on ebay. I put my hard drive in parts one and my hold switch now all i get is connect to computer use itunes to restore, which I would do but itunes does not see the ipod. I tried switching back same thing in all combinations both worked before. The new one just froze sometimes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Ok must be a apple cord the other that i have is a belkin it works sometimes but would not work when I first put it back together so all is working now took three ipods to make two
完成的
Good job, great trouble shooting. Good Luck
完成的
添加一条评论
1个答案
已选择的解决方案
john, make sure that you connected all the ribbon cables and closed the clips to hold thew cable in. Also try to place the iPod in Disk mode and see if your computer can find the iPod as a drive. You can also try the diagnostic mode and see if where and if it hangs up. Also make sure that you dock connector does not have any bend or accidentally broken pins. Let us know what you get
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 416
